You're right, it shouldn't matter when linking it with the Castle Link. Hmm...still sounds like something with the low voltage/control section of the ESC if your fan won't spin up. Heck, put a voltmeter across the red and black on the Rx harness when you plug your batt in. It should be 5+volts.
Your right, it shouldn't matter when linking it with the Castle Link. Hmm...still sounds like something with the low voltage/control section of the ESC if your fan won't spin up. Heck, put a voltmeter across the red and black on the Rx harness when you plug your batt in. It should be 5+volts.
Sounds like a partial short in the low voltage section of the control board. I'd say it's bad enough to warrant getting an RMA and sending it back to Castle.
