tha5150
tha5150's Avatar
05.12.2008, 08:02 PM
well, i took the diffs apart and saw nothing significant. i am soaking everything in acetone right now and will attempt to put back together tonight. need to clean all the crap off and re-grease them. i will take some pics once i have cleaned everything for your viewing pleasure.
one thing i never tried on my narrowing down the problem process though. hooking everything up except the wheels and seeing what happens.
the motor turns freely when not connected to the pinion.
pinion to spur to tranny spins fine.
driveshafts to diffs is where the problem was. but i never checked it without the tires on to see if it spun freely without the binding. that is my mission tonight..
almost forgot, i got these today for 100 bucks shipped.
Buzzsaw46
05.13.2008, 02:49 AM
Nice, Comobs? or are they Hybrids?
tha5150
tha5150's Avatar
05.13.2008, 08:21 AM
well, i put everything back together last night but didnt get a chance to install in truck. i saw no point since those bulks will be here tommorow. i will pop the new ones in, see if its the same problem. if not, i know it is the esc or the motor. then i have a whole new bag of issues to deal with.
Duster_360
05.13.2008, 08:56 PM
Those'll work far better than those you linked from Ebay! I bought ofna diffs from a guy on UE for $80 - same ones UE includes in their 6 spyder Ultralights.
After you get diffs and pinions, find some shims and set them up right. If you've never done it, go over to UE and find their setup instructions for theirs - well documented, lots of pics, and easy to understand. Once you see these, you'll know what need to do for yours.
tha5150
tha5150's Avatar
05.14.2008, 08:19 AM
huh? the pics of the combo diffs are from ebay, yes. and those are the ones i got. i am confused, what are you saying here?
edit: i cant find that write up. link?
Duster_360
05.14.2008, 07:34 PM
The diffs in the red alum cases from a while back (your ebay link in your posting #21) - just stock maxx diff parts assembled in a set of alum diff cases - the combo bulks you picked up will be much better than those, obviously.
http://www.unlimitedengineering.com/instructions.shtml Go down 11 or 12 items to the Ultralites and click on V1.5 - that opens a pdf - UEs build instructions. Save it to your PC, print it or whatever you want to do.
