Matthew_Armeni
Matthew_Armeni's Avatar
05.13.2008, 10:55 AM
On RCZone they say the Kyosho uses a worm gear drive. If that's true, it will have unbelievable torque and holding power (since the main gear can't spin the worm gear, no coasting either). Should be an interesting gearbox
  Send a message via AIM to Matthew_Armeni
Andrew32
10.06.2008, 10:12 AM
actually a worm gear can back drive.....iv done it
but oyur right on a rig like this, you can do some precision driving. But i really hope the casing is tough! cuz worm gears are rough on housing
11.27.2008, 12:08 AM
I have a design for the axial crawler to use worm drive. I was going to use steel for the tubes and center section, mainly cause I can weld (and have a $1700 welder) plus they will be very sturdy, can be made more compact, and the weight is where crawlers need it, low. Also the steel parts should hold together better under the load of the worm. I will need some big bearings, and plan to offset the gears to alow for better servo mounting. Plan to use stock axial c hubs and knuckles. Axles may be custom, or I will integrate some sort of existing cvd axle.
