Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
05.13.2008, 03:50 PM
So how can they list in the specs that 18 cell NiMH or NiCD is ok? There is no way that NiMH or NiCD can deliver that kind of current.
This still doesnt make sense to me.
You don't need a lot of current if you were to run a lower kv motor with light gearing...it's all how you use the controller. ;) For the R/C industry you're probably not going to find many people running NiMH cells with the Monster, but we had to put it up there or I'd be answering a lot of emails. ;)
Joe Ford
Product Specialist
jhautz
jhautz's Avatar
05.13.2008, 04:52 PM
But in the extra card that came with the MMM it said that it required a minimum of 75A continuous and over 125A burst. Why would this statement be accurate then?
to make it...
or break it...
Silent...But Deadly
crazyjr
crazyjr's Avatar
05.13.2008, 05:04 PM
I think its, for the new to brushless guys, that don't have the experience we have, to determine what loads we will put on them.
Joe Ford
Joe Ford's Avatar
05.13.2008, 05:56 PM
That is with the 1515/1Y in a typical setup. I stated if using a lower kv motor and light gearing you could get away with NiMH. ;)
Joe Ford
Product Specialist
Toyman
05.13.2008, 06:35 PM
I have a MMM on the way from Mike, I run Nimh will my 14 cell GP 3300's and 8XL work ok??? Steve
dubkatz
05.13.2008, 06:51 PM
and im close to that im running a 9xl and either 14 gp3300's or i built 2 8 cells packs, that i plan on running too. Yes i bought a lot of gp3000's along time ago.
jhautz
jhautz's Avatar
05.13.2008, 07:05 PM
Thanks Joe, I wasnt sure what your baseline was for "lower". Got it now. So all of this setup info is based on a 2200kv 1515/1Y on 6s? I would imagine running that same motor on 4s would not require the same battery capability either provided gearing didnt change.
Just to be clear can you confirm this for me...
Then with a 1512/3D (1700kv) shorter lower kv motor in a light 1/8 buggy and conservative gearing (35-40mph) I could run a lipo that isnt quite up to the 75A/125A specs and get away with it without damage to the Monster.
Sorry to be a pain, I just read all the bolony that has been posted the last couple days in this and "other" forums regarding the Monster and lipos that may not be up to the task causing the reported dead MMMs and I want to be clear is all. And hearing it directly from someone at CC is better than all the hearsay floating around at this point.
to make it...
or break it...
Silent...But Deadly
xtremelimits285
E8ight T
xtremelimits285's Avatar
05.13.2008, 08:10 PM
+1
Joe,
i run a 8T with a neu 1515 1y on my mamba max an external bec, ive been running on my 3s2p 8000 maxxamps pack, gearing around 32-38mph max( ive been haveing no overheating an no problems an can max 20 min mains....
(can i gear up, up on 3s to 45 mph max..ON THE MMM)
can i keep running my 3s8000 pack(if geared under 45mph), or do i need to run my 4s6000, or 5s2p 8000 maxxamps pack???
BTW i always run low settings (never under 30% acclimit usuly 70%, an never run more then 5-low motor timming)my LVC is set at 9.2v for 3s on my mamba max should i change any setting for the MMM?
Whats best for 38-45mph racing (an last 20in mains)?
on the 1515 1y/f in a 1/8th scale truggy(trying to keep the weight down)
3s 8000?
4s 6000?
5s 6000?
(a 5s8000 pack is too heavy)
looking to buy another pack(have 3 allready)
thanks
gary a.
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
nativepaul
nativepaul's Avatar
05.14.2008, 12:47 AM
Good NiMhs are capable of that and more, holding reasonable voltage while doing it, just not for long, F5B flyboys were pulling over 300A from NiMhs in 3 second bursts before they switched to LiPos and boat and pylon guys were pulling close to 100A continuous, but at those levels your lucky to get half a dozen decent runs out of a pack before it either significantly drops capacity and voltage or goes pop.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
Joe Ford
Joe Ford's Avatar
05.14.2008, 12:18 PM
100% correct...I'm one of those pylon guys...100A continuous plus in my F5D's...the batteries get about 10 cycles and then I throw them away. Same for the F5B guys. :)
For "getting away with batteries that handle less than 75A", NO, DO NOT DO THIS. If the controller fails due to ripple current we can't cover it under warranty, and you may lose your batteries in the process. Better to buy expensive, buy once.
Joe Ford
Product Specialist
lutach
lutach's Avatar
05.14.2008, 12:23 PM
Is there any way to overcome this issue with the ripple current?
05.14.2008, 12:29 PM
The only way I can think of is more capacitance. But it gets physically difficult to mount more so near where they need to go...
lutach
lutach's Avatar
05.14.2008, 12:53 PM
Cool, that's what I thought, but needed to be sure. That works for me then. Thank you Brian.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.14.2008, 12:46 PM
Hmmm I have just seen your post, will 1p A123 packs work?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
