Questions???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Questions??? - 05.14.2008, 04:02 AM
Ok I just received a set of hybrid bulks from RCM and I also purchased a set of Hot Bodies Diffs with hardened steel gears to go in them. I got the 10 tooth helical pinion to go with the setup and man is it beefy. I never knew that they were so heavy duty. I am truly glad that I decided to put this setup together and use it in one of my trucks just to try it out. Now I am sure that I will be purchasing more to convert my other builds. Anyway my question is this. I have everything I need to put these hybrid diffs together except for the pinion gear bearings. What is the size of those bearings and are they listed anywhere? Also is there an aluminum diff cup out there to fit these HB diffs? Any info or links would be grately appreciated. Thanks guys.
Duster_360
05.14.2008, 07:03 AM
Those should be std brg 8x16x5mm, I used Ofna diff kits to build my hybrids with and those were what it took. Any brg place will have them, I used the Avid Revolutions in them.
http://www.avidrc.com/shop/?action=i...=1&prevstart=0
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
05.15.2008, 12:53 AM
I can take measurements of a jammin one if it helps? I know nova makes cups for the jammin, they look almost identical to the HB cups.
rccna.com
SpeedAssault
SpeedAssault's Avatar
03.26.2009, 11:14 AM
its me Build is Frekin awesome , that thing is going to be a blast to drive
I', building something similar but more of a rally sedan
Sorry to intrude
but I am reading different stories on Hybrid diffs. not all the info seems to be there
Can someone tell me what exact parts are involved ?
I read about emax/revo bulkhead with LST Diffs
but I also read Muggy diffs ..? which is it.. confused
I greatly appreciate the help, thank u
its me
its me's Avatar
03.28.2009, 03:57 AM
Sorry to intrude
Ah all the diffs that im using are from either the lst or muggy.
rccna.com
