MetalMan
MetalMan's Avatar
05.15.2008, 07:29 PM
Got mine today from Mike. Installed it in MM's old revo with the slipperential. Running a hacker 7xl b50 on 4s (2 trakpower). Ran it for 15min and it worked fine. This is a high draw setup, but the esc stayed cool. I used the internal bec and it worked fine for me, so I guess that I got a good one! Mine came with connectors in a little baggy, so I used them. Nice connectors, I will have to buy some more, what size are they, 6.5mm?
That is an awesome setup! When I had that Revo I ran a Feigao 7XL through a MM on 5s2p A123, with a 20t pinion. Top speed was ~45mph, and the 7XL (finned can) didn't go over 160deg. F. The MM on the other hand would thermal in a couple minutes without a fan. If only the MMM had been in production while I still had that truck...
And yes, 6.5mm plugs.
