Five-oh-joe
05.16.2008, 09:48 PM
Anybody have a link to some Low-ESR caps that are similar to what is on the Mamba Max ESC? I was thinking about adding a cap bank to help it run a little cooler (only gets to around 120F with a fan and a medusa 4800 kv pulling some hefty gearing). I would like it to run even better though... It's starting to get into the low 90's down here in Florida, so I'd like some extra cooling insurance.
Also, I should solder them closest to the power leads, yes?
lutach
lutach's Avatar
05.16.2008, 09:52 PM
You can look around www.newark.com, www.mouser.com and www.digi-key.com.
Edit: I got some Axial type capacitors that I'll be adding them up. They are the same width as most of the ESC I have and I'll probably hook it up to my Scorpion controller. They are Nichicon 50V 1000uF each. Should make a good bang when connecting .
GriffinRU
05.18.2008, 05:29 PM
Have you checked the links under my signature?
The best caps for our ESC's in current form factor would be Panasonic FM-type. Check datasheet for lead spacing and dimensions, look for lowest ESR and voltage at least 25% higher than you battery Voltage.
I like Atmel's and there is nothing special about finding rotor position without spinning, but tricky :) Solutions available but not every programmer now how to do math (or willing to do math...) on micro without floating point support...
