andywpj
05.17.2008, 05:24 AM
Hello 3905er,
this problem seem like MMM don't support FUTABA PCM1024 mode.
If your receive is R113ip PCM1024, maybe has some problem.
Try change other FM (no pcm) with PPM receive.
Hope this help.
Originally Posted by 3905er View Post
well guys I cut the leads down to a nice lenght,changed the punch control to %60 changed timing to 5 degrees and after 4 or 5 minutes i get the same cogging and glitching and it starts running in reverse. So I change my batts to some cheapo venom 3000 mah nihm, and the problem goes away I run for 5 to 8 minutes with no problems is it the true rc lipos i am running they are rated 96a(15c)cont. 128a(20c)max.
Update
3905er
Update - 05.23.2008, 11:07 PM
Sent the controller in per request of castle engineer. Got it back today And it does the same thing. Tonite after work i put the stock radio in for the heck of it and what do you know it runs fine for 10min straight. So i guess Andy was on to something I just don't have any fm receivers to try it with.
3905er
05.25.2008, 12:26 PM
Just finished running my truck with a fm receiver and it runs great so I don't think I ever had a problem with the monster. I think it was a frequency issue with my pcm reciever.
andywpj
05.29.2008, 01:22 AM
no, not frequency issue.
why futaba pcm receiver can't take mmm esc, becase the futaba pcm receiver inside pcm decoder ASIC out voltage level too low.
ppm high signal is 2.2~2.3V but mmm can't identify it is high.
so how to solve problems, just put a fail-safe unit in ch2, that's level go on 5v mmm can take and Run fine.
and why not use 2.4g or DSM receiver because range issue.
Hope this help..
