speed demon
05.17.2008, 12:16 PM
OK I put in another motor that works fine. Soldered it all up and the same thing happens. It takes off and runs fine for a min or two then it start cogging then I lose a ton of power. Also the MM just shuts down after so long and most of the times comes back on. The MM was not even warm yet and the motor was 120. I'm alittle lost anyone have any ideas?
speed demon
05.17.2008, 02:19 PM
Yep you guys were right the mega motor is junk. When I was running the other motor it was acting up because my 4S was at 10.6volts. I charged it back up to 16.8 and had no problems running. Dang I'm stupid. I know the voltage cutoff doesn't work at custom 12.3 or 12.0. Glad I bought one of those antipuff lipos. Guess I'll try the medusa motors.
