Go Back   RC-Monster Forums > Support Forums > General Nitro
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
09.22.2005, 03:26 AM
Well coolhand, I had allready adjusted the rod/slider that you were talking about prior to you mentioning it. So I checked it again just to make sure and re-adjusted it. Then wouldnt you know it, I took it out to test it, made a couple of passes, and before I could test the reverse, it stalls.....and wont restart.
Now I have another problem, it still wont start. I checked the glow plug and it looked fine. So I grounded the glow plug on the side of the engine to see if it would glow, gave the EZ-start a workout for about 15 seconds and no glow. So I put in a new glow plug and still no glow. Then someone tells me that there is a chance that my EZ-start wand is bad. So I bought a new wand and the glow plug still isnt glowing. Now I am in the process of changing the wiring harness to see if that is the problem. Sheeesh!
I'll let you know if that was the problem when I get it installed, but if you have any sugestions, please let me know, because I have no idea where to go from here if the harness doesnt work.
Thanks.
