Just want to thro my opinion out there on the Nomadio react. I has used the 3pk and like the react better.
Pro-
4 channel
Computer programmable and unpalatable
light wieght
very very fast response time
Con-
battery is cheap
and plastic looks cheap but is tough!
rx's are kind of big
Pro-
4 channel
light wieght
Con-
battery is cheap
I was thinking this too, but these radios are almost impossible to buy since there never in stock..
you can find them pretty frequently on ebay. A react with a receiver should be around 200-220 used...
Still alot cheaper then a futaba 4pk with some more features.
And they (react and sensor) can run spektrum receivers.
(Note - the sensor you must have a laptop computer to switch it from nomadio to spektrum. The react has enough on board memory to just switch back and forth. So no laptop need for the react.)
