Originally Posted by BOOGIE444
I did adjust my throttle trim on my radio after I progamed the esc. Maybe it just needs to rearm with my radio / settings? Maybe when I go to full throttle the esc is seeing it as nothing because the trigger is moving to far or something, I dont know. But my temps arent getting very hot with this gearing.
that is what the calibration is for! Calibrate the ESC and then you know it is not cutting out because of this.
To calibrate the esc to your radio
turn on radio
hold radio full throttle
turn on ESC
it will beep then hold full brake
it will beep again
release to neutral
will beep again and then arm
