Pdelcast
Pdelcast's Avatar
05.19.2008, 12:20 PM
Originally Posted by bruce750i View Post
I just thought something was in the drive train making a clicking noise, so I tried reverse (sometimes that clears the it out) nope still clicking. So I drove it back to me to investigate the clicking. MMM 6s power had popped the end bell, and split the magnet. The motor was at 195f and the rotor was just slapping around in the windings when I was driving it. But the MMM just keep on feeding the amps. It ran for about 30 min run time total mostly street then I hit the dirt for some rooster tails and over rpm it a little by 20000
Lucky you didn't kill the MMM too. IF the motor was that hot, you were a little over geared to run for that long...
Patrick del Castillo
President, Principle Engineer
05.19.2008, 12:22 PM
Plus 6s is a bit much for the 8xl. The high rpms may have killed the magnet. At least it was a cheap motor.
bl-is-future
bl-is-future's Avatar
05.19.2008, 12:50 PM
Yep 8xl is only rated for 40000 rpm and at 6s it is going about 45000
