azjc
05.19.2008, 08:39 PM
Originally Posted by q8-maxx View Post
Differential Ratio: 2.8461538461538462
Transmission Ratio: 2.111111111111111
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 5.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1.8 : 1
Total Ratio: 10.81538 : 1
Tire Circumference (inches): 17.59 inches (446.86 mm)
Total Motor Speed: 37000 RPM
Vehicle Speed: 56.99 mph (91.55 km/h)
Effective Speed Rate: 3.08 mph/V (4.95 kmh/V)
Estimated Adjusted Speed: 53 mph (85 km/h) - 8% loss
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
5.6 stock revo tire :)
you do have a pretty big pinion I would go with a 18 tooth , your tires will balloon that would be ok for your on street speed runs but if you want to off road at all gear it for 40-45 mph, also I would stick with the 5s
e-rev project
05.19.2008, 09:04 PM
ok ijust measured my hv 6.5 its almost 70mm long will the torque compare to the 60mm long medusa?
now im confused again
05.19.2008, 09:42 PM
The medusa will outperform the novak. As long as the 3700 lipos are 25c they should be ok. You will find that 50mph is a bit much, gear for 45mph and you will be happy. I do not see any issues with your setup, just make sure you have a few pinions and spurs to get the gearing just right.
e-rev project
05.19.2008, 09:49 PM
ok perfect just for the record the gp3300 X 14 were a reference to my e-maxx i plan on useing the 5s1p zippy 5000mah packs
thanks again
you guys are very helpful
kostaktinos_mt
05.19.2008, 09:47 PM
50mph is quite a top speed for any MT... if however that is your goal, the 36-60-2000v2 medusa will do it on 6s...
5s and 40ish mph would be my personal pick; however, it`s your call in this case of course...
i don`t believe that the 75mm novak has more [or even equal] torque to a good 4pole 60mm motor...
  Send a message via MSN to kostaktinos_mt
