lutach
lutach's Avatar
05.20.2008, 12:35 AM
Originally Posted by evader View Post
ok, well I just noticed the red programming bridge has come unsoldered. Can I just solder it back on?
Yes. I had to do it on a few of my BKs.
evader
05.20.2008, 06:30 AM
I'm still getting that stuttering thing happening when I give it full throttle. I've re-programmed it several times now but it keeps doing it.
Anyone have any ideas as to what I can do to fix it. I've had this truck now for about a month and I would really like to get it out and run it
Thanks
jhautz
jhautz's Avatar
05.20.2008, 07:46 AM
What motor are you running? The BK controllers only like the 2 pole motors like the Feiago, Lehner, Hacker. It wont run well with a Neu or Mega or any other motor that is more than 2 poles.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
05.20.2008, 07:47 AM
If you have one of the high amp models, the rpm limit is only 42000rpm.
evader
05.20.2008, 12:21 PM
it's the Feiago motor. It was running just fine for the guy I bought it off of. He was running a dsm radio and receiver (I'm not). I've tried 2 different receivers so far but am still having the same problem. It seems to be alright if I ease onto the throttle...but when I hammer the throttle it stutters.
I don't know a whole lot about this stuff...that's why I bought it from someone else and didn't build my own. I was hoping to just be able to put my receiver in it and go...
Like I said, I don't know much about this stuff but I wasn't sure if maybe my receiver was too close to the esc? I've attached a picture of how it is set up.
Somebody mentioned to me that I might need something called a "glitch buster"?
Again, any help would be greatly appreciated
Thanks
05.20.2008, 12:25 PM
I am guessing that the white shrink wrapped thingy is the ubec. They produce some interference, and may mess with the receiver. Move the receiver away from any of the power and ubec wires, maybe to the other end of the truck.
Dsm is not usually affected by ubec interference, while yyour fm may be. Just move the rec around until you fix the problem.
lutach
lutach's Avatar
05.20.2008, 03:46 PM
One of the jumpers is for calibrating your controller to your radio. Have you done that yet? It is the jumper right next to the capacitor and the other jumper is if you want to disable the BEC. (I might be wrong, it's been a while since I messed with my BK ESCs).
