Need center diff help…
xcntrk
xcntrk's Avatar
Need center diff help… - 05.19.2008, 08:58 PM
Hey all, could use some advice about a center diff setup. I just converted a Ofna Hyper-7 over to electric using an RCM mount, Neu 1512/2.5d on 4s. I replaced the center fluid with 130k, new seals, and run 46/13 gearing.
First run out everything performed well for about 10min until I blew the center diff. Prior to the damage the front-end still seemed to unload a bit slipping the center diff nearly all the way up to top-speed before it seemed stopped unloading; even with the heavy 130k. Upon teardown, the entire diff gearing is shot. One bevel gear and all 4 spiders teeth are munched.
Is there a logical upgrade for the stock center diff? Something strong, perhaps a 6-spider, maybe a torsen-style? Or should I just replace/fix the damaged gears and give it another go? Is the center diff the same as the front/rear diffs? What fluid should I be running or is this dependent on number of spider-gears?
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
05.19.2008, 10:00 PM
Interesting. Did you use a plastic spur or the stock steel one?
You may have too much clearance in the center diff, and the gears are not meshing up properly?
xcntrk
xcntrk's Avatar
05.19.2008, 10:23 PM
For whatever reason, when I did a dry test-fit of the RCM mount/bulkhead I had a bit of excess slop with the diff slightly moving from front-to-back. I did a little research and found this can be solved by stacking the diff gaskets between the spur and diff housing. I started off with 3 but feared the bevel gear was too far off the spiders and could jump. So I dropped down to 2 gaskets and sealed her up. May have been a contributor to the issue. I could rebuild and drop back down to a single gasket, but that won’t help my RCM bulkhead slop any.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
bdebde
That's All Folks!
bdebde's Avatar
05.19.2008, 10:26 PM
You can also use shims on the outside of the bearings.
05.19.2008, 10:31 PM
One gasket worked for me, but the gaskets are different thickness depending on mfg. Do not use one and see if the diff is too tight. If not just use silicone sealant to prevent leaks. Or if it is too tight just use one gasket, and shim the bearings to get a good fit in the bulks like bdebde said.
xcntrk
xcntrk's Avatar
05.20.2008, 12:46 PM
Anybody got an easly link for the right size bearing shims? The lip (race) on the bulkheads has very small mounting surface where the bearing actually sits. I've hunted around and still come up empty handed trying to find a good fitting shim. Does ofna make one specifically for this purpose?
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
05.20.2008, 12:58 PM
I have a Hyper8 and have no trouble with stripping gears at all. I think using two gaskets is definitely what caused them to strip - only the tops of the gears were meshed. Do what linc said: use gaskets that will properly shim the diff internals and use large shims on the outside bearings (between the CD mount and CD) to take up the slack. Only two or three should need to be used.
tc3_racer_001
tc3_racer_001's Avatar
05.20.2008, 05:18 PM
hi there, ive got a h8.5, will the hyper mount fit, and will i need to shim the cd or not (will there be any movement?) and what are these gasket things, never heard of them!
sorry for the random question, just seemed like a suitable place to get my question answered! (i went for the standard diff so thje kyosho plastic spur should fit...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
05.20.2008, 05:29 PM
These: http://www3.towerhobbies.com/cgi-bin...?&I=LXCWN2&P=7
Thery're cardboard seals you put on the diff before you screw the end on. Keeps them from leaking.
xcntrk
xcntrk's Avatar
05.20.2008, 07:43 PM
^right; but as posted from my experiance (lessons-learned), these should not be used to address any diff movement within the bulkheads. Instead, looks like shimming the bearing is the proper approach. These are what I ordered to hopefully fix the slop.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
