jzemaxx
05.21.2008, 11:01 AM
That motor should be able to pull it that fast. The calculator above 75 though starts becoming in-accurate. The drag factored in must not be enough......
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
05.21.2008, 12:15 PM
The drag factor is a VERY rough estimate. In very streamlined setups, the factor may be too high; in not-so-aerodynamic setups, the drag may be too low. So, I opted for "about in the middle". A MT is much different than an on-road car.
If the mood grabs me, I might add a drop-down box so the user can select vehicle type. Similar style vehicles should exhibit somewhat similar drag characteristics.
lutach
lutach's Avatar
05.21.2008, 12:24 PM
Here are some datas of a few 2250, but not the 2250/10:
http://www.lehner-motoren.com/motord...250-11.33V.xls
http://www.lehner-motoren.com/motord...20HA%2049V.xls
http://www.lehner-motoren.com/motord...6%20HA.24V.xls
http://www.lehner-motoren.com/motord...6%20HA.28V.xls
This should give you ideas of how well the 2250 will do.
jzemaxx
05.21.2008, 12:30 PM
That would be awesome...I can give you feed back as to how much you will need for the drag estimate given all the runs I have done with my setup.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
