Shark413
Shark413's Avatar
05.22.2008, 01:57 AM
Well no more machining for a while, my bad machining skills blew the gear box in my mini mill. But I was able to finish the spacers the old fashion way, saw, dremel and files.
Broken gear - Mini Mill
Carbon Fiber spacer for front diff support
Aluminum spacer for diff/motor mount.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
cen
cornolio
cornolio's Avatar
cen - 05.23.2008, 04:02 AM
hi shark413,im the guy who got your old cen conversion.im having so much fun with it with the MMM.only problem is i keep stripping spur gears.i stripped 3 already and and im not even doing any jumping.i got a steel spur gear but im reluctant to try it coz i might melt my pinions or something else.can u give any advice?id appreciate it.thanks
  Send a message via Yahoo to cornolio
Shark413
Shark413's Avatar
05.23.2008, 01:09 PM
cornolio, glad to hear from you. I also had issues with stripping the plastic Kyosho spur gears, so I swithced to steel spur and a hardened pinion. I have been running these on all my brushless conversions with no problems. The important thing is you must use a Mod 1 hardened pinion, which RC-Monster, Impaktrc, MegaUSA all sell. I am also using a wide Robinson Racing Losi spur gear that is wider than normal and spreads the contact area out more, which improves wear on the spur and pinion as well.
http://www.amainhobbies.com/product_...ducts_id/12711
Spur comes in 47, 48 and 49T.
cornolio
cornolio's Avatar
05.23.2008, 01:48 PM
thanks shark.sorry for hijacking your thread
Shark413
Shark413's Avatar
05.23.2008, 04:20 PM
cornolio, no problem. Just to clarify, if you switch to a steel spur the hardened pinion is a must. The wide Robinson Racing steel spur is optional and a nice to have but not a requirement.
