Electric Eel
05.25.2008, 01:49 PM
I had the 2300 kv motor. If you kept the gearing at 14 tooth or lower pinion, the heat would be reasonable. Any higher and it would heat up hot near the end of the pack. The 1521 is the better choice. Put some spacers under the motor mount for clearance and you are ready to go. I just ran my 1521 with some Jumbo Kong tires for fun. My Fastlane super thick outdrive dogbones actually twisted about 90 degrees on one wheelie! Ungodly torque on these motors. Also, watch your foams. It sounds crazy but stock Pro-line foams will wad up and deform after a while. Do they make a molded foam for the 40 series?
Mikey007
05.25.2008, 03:03 PM
If I went with a lower kv 1527 then the heat would be less of an issue correct? How much power difference between the 1521 and 1527? I'm not a 100% positive if the foams are molded on the 40 series, been a while since I had them off.
Electric Eel
05.25.2008, 03:27 PM
You could go with the 1500kv 1527, but I wouldn't recommend it. These motors just pull too much current. A higher volt 12S ESC would be fun to try. As for power differences, I think the 1527 is just too strong for a Savage. The parts aren't made to handle it. Even the 1521 is probably too much, but a careful throttle finger works wonders. The 1521 will flip it right on its lid every time, even with the wheelie bar attached. If you want to beat the nitro guys, I would suggest a 1515. It will easily pull past the nitro and be controllable and reliable enough.
To sum it up, 1521 for hard core basher. Racing and higher speed runs against nitro-1515. The 1527-crazy but not really drivable.
