5s1p A123 is quite weak - 1000amps peak. Running 5s2p in my "slipperential" Revo (the one which lincpimp now owns) I would get 10-15mins with a 7XL and MM geared for ~45mph top. Since it was a custom conversion with the motor only slightly offset to the left side, I could easily run 2s2p next to the motor and 3s2p on the right side to achieve decent weight balance and CG.
Knowing that the Fiego motors are not very efficient and tend to crate a great deal of heat maybe a motor upgrade would give you slightly better run times, not to mention better performance overall. just a thought....
