05.27.2008, 09:10 PM
Should help temps by 10 to 20 deg. I would run a ccbec and disable the mm internal bec. That will drop temps on the esc quite a bit, and is definately worth 20bucks. Plus the ccbec is adjustable via the castle link. Out of the two, the bec will be the better mod for 3s use.
