lutach
lutach's Avatar
05.28.2008, 01:21 PM
If you don't need that gear, just use a Dremel if you have one and grind it out. One of my Aveox came with a gear box and when I took the gear box out it had a 32 pitch pinion glued to the shaft. I did everything to try and get it out, but my Dremel needed some action . After your done just sand the shaft a bit with fine grit sand paper.
05.28.2008, 02:47 PM
I usually use a chainsaw and a plasma cutter. It takes a bit of imagination to see how I did it that way.
