update
jefierro
jefierro's Avatar
update - 06.01.2008, 03:48 PM
i have the following on order:
  1. Kyosho Lazer ZX-5 SP kit
  2. HS-645MG Metal-Geared Hitec servo
  3. Pro-Line Inside Job 2.2" M3 Front & Rear
  4. Kyosho Spur Gear 48P 76T & 78T.
  5. Xtreme Racing Kyosho Lazer Thick Silver Carbon Fiber Front & Rear Shock Tower.
  6. Kyosho Special Blue Aluminum Front Suspension Holder
  7. Tony's Screws Kyosho Lazer ZX-5 Screw Kit
  8. Align Hexagon Screw Driver Set (1.5, 2.0, 2.5, 3.0mm)
  9. and some other stuff.
RTR vs kit(pro) - again there's no difference, i think, over the carbon composite materials use in both versions, it seems they are made with the same material. I've chosen the SP version for the purpose of building it from scratch and also i hate cheep servos and AM radios, those where going to be upgraded aniway, also i heard good things about the SP shocks, not that the rtr are bad, just the SP ones perform better.
I have tecnical problems with amainhobbies with shipping requirements but i hope to have this order on its way next week.
I had left the brushless system for last as I haven't desided witch one or witch will work best i still need to digg up some more info, but I think the mamba max 5700 or 6900kv will do fine.
thanks again
  Send a message via MSN to jefierro
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.01.2008, 05:00 PM
What batteries are you going to be using? I was running a 6900KV in my XXX-4 and BJ4 and on 6 cell nimh it was fast
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
jefierro
jefierro's Avatar
06.01.2008, 06:19 PM
i have 2X 2s 5000 MA lipos and 4X 4200mAh sxs 6 cells, probably just lipos as i plan to sell the other batts but maby i'll keep two.
after reviewing top speeds on the MM types i think the 5700 is a better suited for the ZX-5
DRIFT_BUGGY
06.01.2008, 06:32 PM
In May issue of Xtreme RC they ran a Kyosho ZX5 SP with a Mamba 6900kv and Peak 3200 Lipo geared at 17/78 and got top speed of 42mph @ 191ft
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Mike_D
Mike_D's Avatar
06.01.2008, 08:43 PM
thanks again
I also have a Kyosho ZX-5 buggy and love it. I am using a Feigao 380c 8T motor with a MM and a 3800mah 6 cell nimh pack and it is pretty fast. I have not had any issue so far. I think you will be very happy with your purchase.
HB Ve8 x 2
jefierro
jefierro's Avatar
Talking 06.01.2008, 11:41 PM
it's done (long live paypal)
here is the final damage:
  2. Hitec HS-645MG High Torque Metal Gear Servo
  3. Pro-Line Inside Job 2.2" M3 4wd Front & Rear Buggy Tires
  4. Kyosho Spur Gear 48P-78T & 76T.
  5. Xtreme Racing Kyosho Lazer Thick Silver Carbon Fiber Front & Rear Shock Tower (4mm)
  6. Align Hexagon Screw Driver Set (1.5, 2.0, 2.5, 3.0mm)
  7. Kyosho Special Blue Aluminum Front Suspension Holder
  8. Tony's Screws Kyosho Lazer ZX-5 Screw Kit
  9. Castle Creations Mamba Max 1/10th Scale Brushless Car Package (6900kV) (5700 was out of stock)
  10. Futaba R603FF 2.4Ghz FASST 3-Channel Receiver (3PM)
  11. Robinson Racing 48P Pinion Gear 15,16,17,18,19,20T
for a grand total of $771.36 this should be a nice father's day present, now to tell the wife
rootar
rootar's Avatar
06.02.2008, 12:21 AM
nice find on the dust cover i just ordered a couple of those
