Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
06.02.2008, 10:04 PM
There is no benefit in adding any capacitors...we put enough on the controller to handle ANYTHING you can throw at it. Do NOT use cheap batteries though. You need high quality cells to run this system...email or call tech support if you are unsure of your batteries' ability to deliver the current. support@castlecreations.com or 913-390-6939 and hit 1 for tech support.
Joe Ford
Product Specialist
Sammus
Sammus's Avatar
06.03.2008, 04:58 AM
Would 7s1p A123 be considered high enough quality? Or would I have to go 2p?
GriffinRU
06.04.2008, 10:53 PM
How you define that?
Why not using cheap batteries? What happen to battery when it is half dead?
What about NiMH?
I thought that bad LiPo are still better then NiCd/NiMh...
Sound like your caps are not up for the task or you just do not want people to add components to your ESC which makes it better.
