jhautz
jhautz's Avatar
06.04.2008, 12:38 AM
Originally Posted by Joe Ford View Post
Same fans...no shipping 1kg of them to Australia ;) , and ANY running without the fan, separate BEC or not, will void your warranty.
Sounds like you boys need to get some fans in stock!!! I'll take 6 please. That should last me a week or so, then I'll place another order. Oh yea... and a flip top esc case would be nice so I don't have to tear the whole dang thing down every 30 minutes or less of run time to replace a fan. I already have 2 tabs breaking off of one of my cases from opening and closing it so much for fan maintenance. While your at it add a couple new cases to the fan orders.
One of the white plugs has already completely broken off of the circuit board from hitting the bottom of the case so I cant even run a fan on it the way it was designed. I guess I'm out of luck on that one. Oh well... when it dies, it dies. Hopefully the Tekin controller is available by then.
Warranty void if running without a fan is the craziest thing Ive ever heard since I haven't heard of a stock installed fan lasting more than an hour.
Originally Posted by lxmuff View Post
I have a hard time understanding the warranty is VOID if NOT using a fan.
The POOR design of the fan in the esc makes it IMPOSSIBLE to run with a running fan.
Those things break within minutes of use.
Why did you not steal the design of the concept that works with modded MMs?
++++1!!!!
Heres a picture of the bulletproof 1/8 controller. Does this void the warrantee? Its the only way I can keep a fan on it.
Originally Posted by dirt101 View Post
where are you guys taking temps. at on the MMM. seems like it would be kinda hard with that large plastic case.
Your right. It is kinda hard to take a good temp with the cage on it. I get the highest readings shooting straight down the top fan hole to the heatsink. I'm sure the internal temperature is significantly hotter than the reading off of the top of the heatsink, but we will proobably never know for sure.
to make it...
or break it...
Silent...But Deadly
killjoyken
RC-Monkey Poo Flinger
killjoyken's Avatar
06.04.2008, 12:50 AM
YES!!! I must have the only magic fan! I've just squeezed past the 1 hour mark!
Damn, now I've jinxed myself....watch it break tomorrow.
jhautz
jhautz's Avatar
06.04.2008, 12:56 AM
Yea, you must. Whoo Hoo!!!! We found one. Now just clone it and send one like it to all of us.
Just curious? What are you doing with the MMM? I think they might be OK if you are just running it around the street or in the park or something. But any kind of rough handeling and they are toast. Mine ran fine all thru set up and some testing at the local park, but the minute I put it on the track it was a gonner.
to make it...
or break it...
Silent...But Deadly
killjoyken
killjoyken's Avatar
06.04.2008, 01:25 AM
Rough handling? More like abuse. Last time I took out my Savage (with MMM) I snapped 1 heavy-duty dogbone, bent another and cracked the shock cap on one of my Aftershock shocks. If it wasn't for the shock cap I would've kept on jumping. 10-12ft jumps...and unlike a cat I don't always land on all fours!
The fan has stopped twice though. 1st time I switched the MMM off then on and the fan restarted. 2nd time a blade of grass blocked it. Removed grass and it worked fine. Also I run in very loose dirt/gravel.
No mods to the Monster. I was running an 8XL, now a 1515/1.5d, both on 4s. I'll probably be running a 1515/1y on 6s this weekend.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.04.2008, 01:06 AM
And you haven't done nothing to it from factory, still original?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
