Steve Krug
Steve Krug's Avatar
06.26.2008, 11:15 PM
Just tried running 14 NIMH cells. The problem is that i'm having real bad acceleration and brakes, also cogging is BEYOND horrible...anybody know what's up?
jayjay283
jayjay283's Avatar
06.27.2008, 12:03 AM
did you change the MM settings to nimh battery ?
Dafni
Dafni's Avatar
07.15.2008, 01:43 AM
Glad you like it! Looks good on your truck.
Steve Krug
Steve Krug's Avatar
06.27.2008, 02:49 PM
Yep I changed the cutoff...
azjc
06.27.2008, 03:22 PM
if you are running an AM radio that could be a major problem
Steve Krug
Steve Krug's Avatar
06.27.2008, 03:33 PM
I'm running DSM.
Tried again with 12 cells. Cogging isn't as bad, but now the ESC is heating up to 130 degrees after one speed pass?? Acceleration and braking is still a problem also! This doesn't make sense. Never had mystery problems like this before. Motor is running real cool, and the batteries are fine ...
Steve Krug
Steve Krug's Avatar
06.29.2008, 12:44 AM
Originally Posted by Steve Krug View Post
I'm running DSM.
Anybody know??
jnev
jnev's Avatar
06.29.2008, 12:58 AM
Hot ESC often times means over-geared... what gearing are you running at the moment?
Steve Krug
Steve Krug's Avatar
06.29.2008, 01:11 AM
13T pinion and stock spur...46T maybe? Whatever the stock mugen spur is....
Honestly if anything this is undergeared. It wasn't doing this before when I was running the 4S lipo. The speedo after running out the 4S lipo had a max temp of 140degrees, and that was after 20 minutes of running.
Happywing
06.29.2008, 08:09 AM
A poor connection, perhaps? Do you use connectors or direct solder?
Steve Krug
Steve Krug's Avatar
06.29.2008, 12:33 PM
I use deans. They seem like they are in good condition..?
Steve Krug
Steve Krug's Avatar
07.14.2008, 10:42 PM
UPDATE
Got the MM problems worked out. I changed the timing to low and start power at low...now it runs pretty good on 12 cells, just not very fast or much power. It could be a good qualifying setup though when lipos aren't available.
Got a package today from dafni with a kick ass body and fan for my MM!! can't believe how well this thing is painted. It's my first "real" authentic custom painted body. All i've had before this was stockers and single schemes.
DAFNI IS DA MAN!!
Also made a slighly cleaner layout. I'm using a modified cardboard box (from the Feigao motor) as my battery mount. Pretty ghetto but hey, it works(sorta kinda), and it was free. I use tape to keep the batteries in LOL. Man is sounds so much worse once I type it on the computer screen lmao.
Peace
Steve Krug
Steve Krug's Avatar
07.14.2008, 10:49 PM
One question..
What size screws will work for mounting a fan...
jnev
jnev's Avatar
07.14.2008, 11:41 PM
I used 3mm self tapping screws to mount the fan to my MM ESC.
Steve Krug
Steve Krug's Avatar
07.15.2008, 12:23 AM
Decided to mount the fan/MM a different way. cut out a piece of spare plastic and mounted to the diff. then took a piece of the "nitro" center diff mount to screw the fan into. Works out alot better than i initially thought. WOW this fan makes a difference.
