azjc
06.04.2008, 07:38 PM
Originally Posted by bl-is-future View Post
neu are rated for 60000 rpm though. I run a 1y on 5s with no problems in a flm savage. Well actually only ran it about 3 times so far but all is well so far. the 1y on 5s is only at 40700 rpm min (3.7v per cell) and 46200 rpm max(4.2v per cell). I don't think neu would rate the motor for 60000 rpm if it couldn't be ran at that.
dont be over focused on the limits of the Neu but usable power, I try not to surpass 40,000 rpms you can have too much power in an off road application resulting excessive wheel spin....try to keep your speed below 45 mph or you will just get fustrated
jhautz
jhautz's Avatar
06.04.2008, 07:41 PM
another thing to remeber about that 60,000 rpm limit. It meant as just that. a limit. It will handle burst to that kind of rpm, but to run it there for more than a few seconds without shutting down to cool after, it would overheat in no time. Neus are high quality motors that run cooler than just about anything else out there, but they arent magic.
to make it...
or break it...
Silent...But Deadly
