06.04.2008, 10:57 PM
Artur, from what you've seen on the MMM so far, is there a way to save an ESC when the BEC fails without sending it in for repair? Like maybe disconnect a BEC component and then use an external one? I've heard a few people blow a repaired ESC which leads me to believe the issue isn't totally worked out yet. I'd rather take a hit on the warranty and mod it then send it in again. Besides, I've already modded it to my liking.
GriffinRU
06.07.2008, 12:06 PM
If you remove inductor then you should be fine using external BEC, but the best would be to remove lm3485 and 2 fets.
