MetalMan
MetalMan's Avatar
06.07.2008, 07:57 PM
Since racing this buggy, I gotta say that so far it's working very well. I didn't have time to set up the mechanical and motor brakes properly, but they still worked flawlessly. Nothing on the buggy broke which was nice because I had no spares...
Only problems I had were when the switch turned off (my fault, and immediately after the race I cut the switch off), and two wing mount screws came out all the way (again, my fault since I didn't thread-lock them).
Although, I did have to run a lot of preload on the springs to keep the arms level, which is an indication that the springs were too soft. Indeed, I would have been much happier with stiffer springs, but they aren't yet available.
The rear end was very loose in corners, but the track also had a loose top surface since all the water had evaporated from the dirt. Also, better tire choice could have fixed this.
Steering is great on this buggy. On a certain u-turn on the track I was accidentally cutting other buggies off because it was taking the turn so sharply.
I definitely look forward to fine-tuning the handling, braking, and acceleration of this new buggy!
lutach
lutach's Avatar
06.07.2008, 09:21 PM
It looks awesome.
Edit: Try the following springs: http://www.amainhobbies.com/product_...ducts_id/12695. I have the one for the Hot Bodies LSP and they are awesome.
tc3_racer_001
tc3_racer_001's Avatar
06.07.2008, 11:15 PM
hi there, nice job! could you please show me how you mounted your reciever/antenna mount thingy... this is something i need to work out! thanks,
ryan :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
MetalMan
MetalMan's Avatar
06.08.2008, 12:34 AM
It looks awesome.
Any chance you can get the inner diameter at the top of the spring and at the bottom of the spring? The shocks on the SH buggy use springs with a larger innder diameter at top, and they taper to a smaller ID at bottom.
ryan :)
It is just a simple receiver mount:
http://www3.towerhobbies.com/cgi-bin...?&I=LX3355&P=7
This is my only Nomadio receiver, so there's velcro on the bottom of it, enabling me to quickly swap it between cars .
Thanks for the comments!
lutach
lutach's Avatar
06.08.2008, 10:22 AM
You got me there . Give Amain a call or send them an e-mail with the diameters you have.
