so if i wanted a gyro for my 3905 emaxx. does that mean i will need two gyros since i have two steering servos? do you have a picture of video on your gyro mounted in your car.
so you disconnect the servo plug from slot 1 from your esc and replace it with the gyro receiver plug, and then you connect the servo plug to the other gyro plug?
If your Emaxx has 2 servos, it has a Y adapter. All you do is disconnect the servo connector from the Rx and plug it into the gyro and the other gyro plug goes where the servo connector went in the Rx str or channel 2. I didn't take any pictures or made any videos of the gyro in action when it was installed, but I've seen a video or two in youtube or from a member here.
