VintageMA
VintageMA's Avatar
06.10.2008, 03:26 PM
Thanks - I appreciate the insight.
Not being a racer (closest track is about 1:30 away from me) and running mainly in large grassy areas and parking lots (as I am sure many do) lends itself to a lot of WOT just due to the wide open space. I guess in that scenario a high RPM motor would be winding all the way up very frequently and maybe getting hotter in an environment where smooth running isn't so much of a concern (and I will say for a fact that the MM with a Neu before and after the Neu firmware update was a big difference - and the MMM seems to run the Neu even smoother - I don't think I've had a single cogging incident).
There definitely seems to be a big difference in setup for racing vs. bashing.
“Everyone has a right to be stupid; some people just abuse the privilege.”
VintageMA
VintageMA's Avatar
06.11.2008, 10:06 AM
Brian - one more question.
What controller are you using with the higher speed running Neu's?
If MM what Punch control setting? If other (ie: MGM) are you using any acceleration limiting?
In my lower 30-35k setups I don't tend to use more than 20-40% punch control, but in a higher ~50k setup I could see punch control set higher to prevent the motor from pulling higher current peak to wind up the motor.
