06.10.2008, 04:24 PM
Check the diameter of the pinion - if 18mm it is mod1
VintageMA
VintageMA's Avatar
06.10.2008, 04:40 PM
As the number of teeth on a gear gets larger, the angle of attack between the pinion and spur changes - so you will see a difference in the appearance of the gears for every 4-5 teeth you go up.
“Everyone has a right to be stupid; some people just abuse the privilege.”
