Current MM still ok on 4s?
SunnyHouTX
06.10.2008, 05:50 PM
I have a habit of using cooling fans on MM's above 4S. Definitely helps. The only thermalling I've had is when the fans aren't working.
SunnyHouTX
Find all posts by SunnyHouTX
2
FG101C
06.10.2008, 08:05 PM
If I run the MM with 4s and a Neu 1515 1/Y do I "Have" to put a thicker guage wire in or will the stock be fine with the stock bullet connectors? I think I may stay off the track since that's where everything seems to break or burn.
FG101C
Find all posts by FG101C
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
