bdebde
That's All Folks!
bdebde's Avatar
06.13.2008, 01:19 PM
Originally Posted by GriffinRU View Post
...MGM hardware with CC software - I am hearing that allot. Patrick have you checked what is different between your creation and theirs?
I would guess by the layout of the MGM, they have more (or larger package) fets. If my third try on the MMM fails, I would be willing to Frankenstein together my MGM power boards with the MMM brains for a totally bulletproof ESC (sorry Patrick).
GriffinRU: can it be done? (brain transplant)
GriffinRU
06.13.2008, 01:27 PM
Not really,
The trick is at fet's drivers not in fets. While they do have nice layout, CC's board is also nice. But there is a small difference which is clear on the board and inside firmware as well. I think if Patrick will do the same, he might get similar performance with current firmware.
But, Frankenstein, in this case would be very complicated.
New MGM's I think have the same fet as CC, if you check old 160Amps ESC had 4 boards now 160Amps has 3 while 224Amps has 4...
