VintageMA
VintageMA's Avatar
06.16.2008, 09:51 PM
Originally Posted by Jeremy1976 View Post
One 5955 is plenty for the Revo. Two in my opinion is senseless and not needed. Plus the benefit of a single steering servo is the servos are not fighting each other draining your battery.
Hmmm... Now there's an interesting thought - but what's the fun of that?
Sometimes it nice to have the security of a nicely ovengineered setup.
If you have read through the manual, they actually have a nice 2-page write-up on how to install the servo horns and steering links and tweak the settings.
“Everyone has a right to be stupid; some people just abuse the privilege.”
VintageMA
VintageMA's Avatar
06.18.2008, 09:10 AM
Noticed that the BEC on the stock ESC is 6volts - maybe that is why things seem a bit slow to me on the MMM.
Regarding gearing - the stock 68T spur is too big. I would like to try out the low CG mount holes, but that would never happen unless you were using a <18T pinion.
Looking into ordering a much smaller spur in the 54T - 58T range (amain has a great selection) and just got a variety of 32P pinions from Mike to experiment with.
bruce750i
bruce750i's Avatar
06.18.2008, 09:39 AM
I'm running something like 21/62 on lower cg mount, with it in the middle of the motor slide, the motor looks nice and low. no run time for testing gearing tho. might fit a 65t spur. 1700kv 6s
VintageMA
VintageMA's Avatar
06.18.2008, 09:56 AM
Looks like you are geared for just over 40mph with those specs.
More info if you can - What motor and batteries are you running?
When you get a chance to run it let us know runtime and temps and how the performance is.
bruce750i
bruce750i's Avatar
06.18.2008, 12:35 PM
Tekneu 1515 2.5D/f / FP 3700'S sure will post up some temps. Right now I don't want to scratch my new ride by driving it.
VintageMA
VintageMA's Avatar
06.18.2008, 12:48 PM
Better put on those heavier springs or it'll be on it's lid first turn you take.
I've got one of those on the side waiting, going to try it with a 3D first and go from there.
bruce750i
bruce750i's Avatar
06.18.2008, 04:05 PM
okay i did some driving on 20/58 and took some temps after ten min i got 135 motor/100 esc/95 lipos check out some videos of it http://s300.photobucket.com/albums/n...t=bb8df352.pbr and i scratched it.
