azjc
06.22.2008, 05:59 PM
I always grind the shaft, and never use loctite. I have never had a pinion come off...so far!
I locktite "everything", my wife thinks I have stock in loctite.....
Peter Zicha
Peter Zicha's Avatar
06.22.2008, 07:11 PM
Here is a homemade jig for making factory quality flatspots
ID:	4851   Click image for larger version
ID:	4852   Click image for larger version
azjc
06.22.2008, 08:10 PM
thats a nice idea...are the square pice of metal you have wielded to each piece of angle iron used to keep the shaft straight?
Peter Zicha
06.22.2008, 09:52 PM
No , If you look carefully they are on the bottom of the jig , they are exactly 5mm thick same as the shaft . when in the vise they keep a consistant distance on the jig clamping the shaft . without those it would be impossible to hold the shaft
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.23.2008, 12:15 AM
Well done, that is a great idea
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
