big greg
06.22.2008, 08:11 PM
you had maxx sized tires on a rustler? can i ask why? how goofy is that lol, thats pushing that sucker to the limits
azjc
06.22.2008, 08:21 PM
I noticed that after I replied to his post...that was an extra factor on why his motor fried
Skelbow
Skelbow's Avatar
06.22.2008, 11:06 PM
When it ran.. it actually ran really well, would do rolling wheelies at 30+ MPH
But he did like I said...
Traded in his full FLM rustler with MM and fried 5700, along with a JR XR3 and his brushless Mini LST and got his 3905 E-Maxx
so he solved his issues
  Send a message via MSN to Skelbow
Pdelcast
Pdelcast's Avatar
06.23.2008, 10:32 AM
I'd like to jump in here and remind everyone -- setup is everything. IF your motor is getting too hot during a run, the gearing is not correct. Brushless will generate as much torque as you ask it to, BUT with poor results if the gearing is wrong.
You should check temps during your first run, and if motor temps are high, gear down. You will often get MORE power and speed with proper gearing than with gearing that is way too high (because the motor is running cooler and in it's operating range.)
Nothing kills a motor faster than incorrect gearing.
Patrick del Castillo
President, Principle Engineer
