harald-hans
harald-hans's Avatar
09.30.2005, 08:33 AM
Originally posted by Nick
So I could have one pack 2 cells and one pack 3 and run around 18v? Each would need charging seperatly?
Do Lipos need discharging/equalising and stuff?
(Sorry for thread hijacking)
Hi,
everything what is divisible or multiplied with 3,7V is what you need:
For example - you want around 18 V - that means 5 cells x 3,7 V = 18,5 V.
You do not have to worry about the number of cells - only look for the capacity you want (4200mAh, 6300mAh, 8400mAh or 10500mAh - that is what is available on www.maxamps.com with 18,5 V), for the voltage you need, the weight you want to care on your truck and the size you are able to accommodate on your truck.
Take your voltage and divide it with 3,7 V and you always know the number of cells you are speaking about (18,5 V / 3,7 V = 5 cells).
So if you have a good charger only told him the voltage, the number of cells, the capacitiy (good chargers do that automaticly) and the Amp`s you want to charge (max. 1C that means if your LiPo has 4200mAh only charge it with max. 4,2 A).
BUT BE CAREFULL - YOU NEED UNCONDITIONAL A CHARGER THAT IS ABLE TO CHARGE LIPO`S !!!
And no, LiPo`s need NO discharging - that is not good for them - you need a low voltage device or a cut off device to preserve of discharging until empty !!!
Hope that helps
Greetings from Germany
harald-hans
