azjc
Question 06.25.2008, 01:51 PM
Check your timming setting on your ESC.
On a "d" wound motor, your timming should not be higher than 10 degre. 0-5 is the best. Higher and it'll heat up.
On a "y" wound motor, you could go over 10 degre
David
David
do you know the theory behind that is? this is the first time I have heard it and I am curious.......
bdebde
That's All Folks!
bdebde's Avatar
06.25.2008, 03:20 PM
Originally Posted by azjc View Post
David
Recommended by Neu (from another forum I believe), as I have heard this as well. Also the instruction sheet that comes with the Neu motors (you do read the instructions right?) says low timing.
david lamontagn
06.25.2008, 04:09 PM
exact, on the Neu website
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.25.2008, 06:01 PM
I didn't get no instructions with my motor.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
KaztheMinotaur
KaztheMinotaur's Avatar
06.25.2008, 06:23 PM
Me neither.
david lamontagn
06.25.2008, 06:35 PM
If the value "10" on the motor timming case is the value giving in degree, i find it little high for a "d" motor. Try to put it at 0, or if you have the option "automatic timming" as on the MGM controller, put it on automatic.
DRIFT_BUGGY
06.25.2008, 06:43 PM
Thanks, ill give that a try, the 10 is what the ESC was set to and it said normal so I just left it at that
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
