Edumakated
06.25.2008, 01:55 PM
Originally Posted by DRIFT_BUGGY View Post
Running a Neu 1512 2.5D on a Losi 8ight geared at 14T/46T (44mph calculator) with 5S 5000mah 25C/50C batteries and MMM ESC. Batteries are only around the 95F - 112F and MMM is 100F - 125F (measuring through the gaps for the heat sink) and the motor gets up to 145F - 165F (it is currently winter here in Australia although no snow etc. still warmish). I am running standard diff fluids for the Losi 8ight Roller F - 3000 C -5000 R - 2000 and measuring it with the Duratrax Temp Gauge. I read on here in the FAQ section that usually when just the motor is hot it is undergeared but wouldn't really think you would need to gear for more than 44mph. Can changing the diff fluid here at all?
Not sure where you are running your car, but those temps are pretty consistent for a Neu under race conditions. Nothing to worry about at all.
You can play with the gearing and check the timing settings on the MMM to see if you can shave some a few degrees off, but those temps are more than acceptable. I keep all mine set to lowest and everything runs great. I pretty much average out about 140-165ish after a hard race. Once you start getting up to 180+ you shoudl be really concerned. I believe the official danger zone is 200+ degrees.
