starscream
RC-Monster TQ
starscream's Avatar
09.30.2005, 08:52 PM
crazyjr,
The only good reason to use the tmaxx tranny is the use of the automatic two speed. If you plan on running a single speed you are better off going with the gmaxx single speed kit.
The plate is a stock emaxx motor plate and is pretty easy to mount. You need a saw, drill w/ counter sink and preferably a dremel. This setup was bulletproof and just as efficient as a stock emaxx motor plate with an even lower CG. Also, this plate will not be effected by chassis flex.
I mounted the plate directly to the t-maxx tranny case via three screws counter sunk from the inside out. You can not see the nuts holding the plate on because they are behind the spur gear.
You will need to remove the excess material that is in the way of the drive line etc.
I don't have the truck anymore, I parted it out for $$$ for my e-Revo. (I know, I probably should have kept it :rolleyes: )
Here's a front view of the truck. the spur is off set enough to cause problems mounting the gmaxx motor mount plate.
Ha Ha
