Desmo
06.28.2008, 10:48 PM
I installed my Novak battery trays today. I ran the elst with 2 2s2p maxamps 8000mah batteries. I put my etrex on it and It showed a max mph of 33.8mph it seems faster (could be the trees blocking the signal). The esc and motor where both 135deg and the batteries where 100deg. I ran it again in race mode to make sure the lvc wasn't cutting in and I got the same results.
Here's the screen shot after the run.
othello
HV basher
06.29.2008, 05:54 AM
A datalogger like an eagletree micropower can only measure with a capture rate of 1/10 of a second. If you use it with a lower capture rate you will miss some amp peaks you would have logged with the highest capture rate. My guess is that the esc measures with a higher capture rate then those of the loggers. And on the other hand ... a logger only sees what happens between Battery and ESC. Even if an ESC only draws 50A from your battery there could be much higher Amp spikes within the ESC. I think Patrick from castle mentioned this in the MMM thread.
It all comes down to: how you measure. At which rate you measure and where. This is why you see such different numbers when you compare the numbers shown in the MGMs software and those of an eagletree logger.
