Electric Eel
06.29.2008, 04:40 PM
I just replaced my 3rd fan. This is getting ridiculous! Is there some secret to keeping the fan intact? Is Castle going to change the design?
jhautz
jhautz's Avatar
06.29.2008, 05:18 PM
I ran thru 5 of the CC fans. My case clips are broken from opening and closing so much as well. I cut all of the fins out of the top fan hole and replaced the fan with an Integy 7.4v 30mm fan and its been running for 3 race days now. The stock MMM fan never made it thru 3 qualifiers before it died and I would end up running without a fan by the time it got to the mains.
Yes the CC fan suck. Hopefully they have it fixed allong with the BEB issue for the next release of MMM in a few weeks.
to make it...
or break it...
Silent...But Deadly
Integy fan not acceptable
redshift
RC-Monster Square Tube
redshift's Avatar
Integy fan not acceptable - 06.29.2008, 07:01 PM
I've used 2 No!vak 25mm fans at 8+volts for no less than 30 hours, holding up fine. They will blow out a candle across a small room, they sound like little turbines too...
I got 2 of the Integy fans cuz they were cheap, thought it would be a good idea to run them closer to rated voltage. EHH!
Even running at 8.4 (their max rating) they move like NO air, and they stink like a fried pcb, the little motors are HOT, I'm wondering if they're already over rated at 7.2.
Anyway most of you probably know all these things are re-branded. You'll almost always see there is one sticker on top of another, peel the top one off and you'll see the Novaks are Young Lin brand, and the Integys are TOPCAD, with an address, topcad.com.hk- FWIW.
Run the Novak 25s at 7-8 volts and they work incredibly well.
