MetalMan
MetalMan's Avatar
06.29.2008, 07:15 PM
1/8 buggies in general are awesome racing machines. I too really like the SH/LRP buggy. Mine jumps PERFECTLY at the local 1/10 indoor offroad track. It's so perfect I don't even correct the nose with throttle, I just let off as soon as it takes off.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.29.2008, 07:50 PM
That was exactly how mine was. It's good to know that even after being converted it still jumps perfect. I'm a bit scared of upsetting the balance when I convert it.
I'm now looking for a motor mount. I measured the hole spacing on the diff mount this morning. The spacing between the 2 diff mounts is 32mm which probably isn't that important. The spacing on the holes in the centre diff mounts is 21mm. Are there any other buggies with the same 21mm mount hole spacing that mike makes a motor mount for? The bearing is a standard 8x16 too.
I should probably start another thread for this.
