83gt
06.30.2008, 01:37 PM
6900kv seems like a lot for 1/10th 4wd. perhaps a 5700 would be better suited to the task ?
jefierro
jefierro's Avatar
06.30.2008, 02:18 PM
Could you elaborate further on that statement? I don't quite understand, is it out revolving the motor?
  Send a message via MSN to jefierro
83gt
06.30.2008, 02:40 PM
Not technically. On 2s you'd be within the motors stated limits, but I found the 6900 and 7700 CM36 motors to run very hot even in a lightweight setup. In my 1/10th 4wd buggy, I was able to move from 7700 to 5700, gear it up a a bit to compensate for the lost top end, and I ended up with a setup just as fast, but with much more manageable temps. As a bonus, the runtimes were much better as well :).
Basically i would only use the 6900 or 7700 series in lightweight onroad cars. When you start putting more load on them, they just heat up too much.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.30.2008, 05:58 PM
I was running a 6900KV in my XXX4 G+ & BJ4 but that was only a 6 cell nimh. RC411/Xtreme RC ran the 6900KV motor and Peak 3200 Carbon Lipo when they did the review on the SP5 in May 08'. They had it geared at 17/78 and hit 42.0mph @ 191ft
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
