07.03.2008, 12:33 PM
Great idea I still prefer the usb hock up personally for the reason mentioned above.
jhautz
jhautz's Avatar
07.03.2008, 01:34 PM
Why do you need a switch? I dont see any reason for needing it. It should work just fine as a Y adapter without a switch. I havent done it with the MMM this way, but I have done it with the R1Pro that way. A Y without a switch.
The only reason I can think that it wouldnt work without the switch is if the internal BEC gets powered with the USB and tries to power the Rx. I wouldnt think so, but possible. It may work any even if it did power the rx as long as you dont turn your radio on.
to make it...
or break it...
Silent...But Deadly
