GriffinRU
07.03.2008, 01:17 PM
Originally Posted by evader View Post
is there somewhere I can purchase just the jumper to see if that's the problem?
Just short to pins together with bare wire, that should prevent you from entering into programming mode and will check jumper as well. You testing with 12cell's NiMh, right?
evader
07.03.2008, 01:49 PM
ok, I will try that when I get home from work today.
Yes, 12 cells and they are NiMh
evader
07.03.2008, 06:19 PM
I just noticed when I was taking the little red jumper off that one of the 2 pin wires isn't soldered to the esc. Here's a picture....I've circled the one that isn't soldered on there.
Could that be why it is always in the programming mode?
GriffinRU
07.03.2008, 07:49 PM
Can you get better focused shot?
evader
07.03.2008, 08:48 PM
It's hard because of the glare from the shrink wrap...but here's what I was able to get. The first one shows where it is supposed to be (I think) and the second picture shows that I can just pull it out...I could pull it out all the way if I wanted to...
ID:	4919   Click image for larger version
GriffinRU
07.03.2008, 09:32 PM
That is how it should look like:
And looks like you correct the wire is loose...not good.
You can try to resolder or attach this loose wire to black (negative) battery lead connector.
evader
07.03.2008, 10:12 PM
how exactly would I connect it to the black battery lead connector? It's not really long enough
