GriffinRU
07.05.2008, 01:07 PM
Originally Posted by evader View Post
well it appears the other jumper has come un-soldered aswell
Since the first one is going to the black battery lead does that mean the other one can go to the red battery lead?
Hold on!
What other jumper???
Do not apply any power before attaching picture. Do not solder in random order.
evader
07.05.2008, 01:22 PM
the red one that isn't being pointed to in this picture has now come un-soldered
GriffinRU
07.05.2008, 01:30 PM
I am just wondering what you do to the controller...
Send it back I will fix it and epoxy everything around, so you can pull entire truck by wires.
If anything this last, unmarked wire, must be soldered to the tiny SMD resistor, cannot be soldered anywhere else. But then you can crack it if not done properly, carefully.
evader
07.05.2008, 01:33 PM
sent you a PM
