07.09.2008, 10:57 AM
The RDlogistics internal diff cases are cheap - $30 for 2 or Mike has the FLM ones for $30 each if you want to go that route.
I would skip the RPM arms - Just go for the traxxas extended rears - I find the RPM ones too flexible.
If you have the strobe slipper at the moment I assume you are mod 1 - Use Briang's script to check pinion sizes once you decide on a motor.
On the Hardened Idler - If you are single speed you will only need one - I recommend the single speed mod.
It might be worth looking at the medusa 60mm - People are finding the run cooler and with the heatsink and the cost of this beast you may just spend the extra $20.
Also you don't need to go as expensive on the charger - I think you might want to re-look at the 1210i which mike stocks - You can charge both packs together with a Y lead and every once in a while charge separatly to balance them.
This saves you $100 which could allow you to buy a Neu motor - A 1515 2.5DF would be perfect and a much better investment in my opinion.
Rgds
Hardstyle
Hardstyle's Avatar
07.09.2008, 02:38 PM
Ok. So the external diff case is useable with the FLM internal case?
Ok. Only rears?
Yes, Mod1. I will check that script
Yes, the gearbox is singlespeed, I think. But I think that last owner has replaced the Hardened Idler.. Have to check that tomorrow
Is that motor 4 poler? BK12020 won't run it nicely?
Does the charging times suffer with this kind of modding? And this 1210i has integrated balancer?
This motor/esc setup is just temporary, I will look the mmm + neu set later... when they publish it...
Sorry for the huge quote
