Finnster
KillaHurtz
Finnster's Avatar
07.14.2008, 11:41 AM
RCM Mike had the 60mm 2000kv in his Erevo this weekend and it looked pretty good. Stayed cool until it broke the revo's driveshaft. Too bad as I wanted to get a better view of it. Not sure if he had on 4 or 5s tho. It was on a MM as well.
Ev1er
07.14.2008, 11:46 AM
So which medusa should I go with then ?
2200kv and 2 x 2s lipos ?
azjc
07.14.2008, 11:54 AM
if you are running 4s
the 2200 will give you more speed but less runtime and potentially a hotter motor...if you plan on ever going higher in voltage I would get the 2000
